Basemap Fader-Enhanced Map Switcher - problem with version 2.5
2089
12-05-2011 10:16 PM
J_B__K_
Hi all,
at first - great and very useful widget, thank you Robert! I don´t know if this is just my problem, but I didn´t find any related post in the forum so I´m starting new thread...
There is the issue that bothers me with version 2.5 - if I move cursor into the pop-up window added in 2.5 (zoom to, transparency, etc.), the window opened by "More..." button closes down (it seems that it kind of losts its focus). The build-in map switcher works fine... Is there any way to make it work as it´s supposed to?
Thanks for help!
Bart
RobertScheitlin__GISP
Bart,
   Thanks for reporting this bug. It is now fixed in the Version 2.5.0.1
Version 2.5.0.1 - Dec 6, 2011
  * Fixed issue with layer menu (more button) disappearing when hovering over layer options menu or alpha menu.
NathanEnge
Hello Robert
I am experience compiling issues with this particular widget///
Description Resource Path Location Type
1061: Call to a possibly undefined method expandLayerItems through a reference with static type com.esri.viewer.components.toc:TOC. MapSwitcherWidget.mxml /FlexViewer/src/widgets/eMapSwitcher line 131 Flex Problem
1119: Access of possibly undefined property SUSPEND_TOC_HIDE_TIMER through a reference with static type Class. MapSwitcherWidget.mxml /FlexViewer/src/widgets/eMapSwitcher line 84 Flex Problem
1119: Access of possibly undefined property TOC_HIDDEN through a reference with static type Class. MapSwitcherWidget.mxml /FlexViewer/src/widgets/eMapSwitcher line 186 Flex Problem
1119: Access of possibly undefined property TOC_HIDDEN through a reference with static type Class. MapSwitcherWidget.mxml /FlexViewer/src/widgets/eMapSwitcher line 262 Flex Problem
what am I missing?
Nathan,
   You have to be using Flex Viewer 2.5 as the widgets title states.
