auto complate
3356
10-29-2014 09:34 PM
MohammedKhamis
Dear all my friends ,
Actually I will try to do autocomplate for search widget but there is not working for me
do you have idea to do that ?
or do you know widget to working like that ???
in the below code of search widget ..
<?xml version="1.0" ?>
<configuration>
    <zoomscale>750000</zoomscale>
    <shareresults>true</shareresults>
    <layers>
        <layer>
            <name>Name of Well Locations</name>
            <url>http://10.14.195.34:6080/arcgis/rest/services/General/General/MapServer/5</url>
            <expression>Name = '[value]'</expression>
            <textsearchlabel>Name of the Features</textsearchlabel>
            <titlefield>Name</titlefield>
            <fields>
                <field name="Name" alias="Name"/>
            </fields>
            <orderbyfields>Name ASC</orderbyfields>
        </layer>
        <layer>
            <name>Name of Roads</name>
            <url>http://10.14.195.34:6080/arcgis/rest/services/General/General/MapServer/1</url>
            <textsearchlabel>Select by attribute</textsearchlabel>
            <fields>
            </fields>
        </layer>
        <layer>
            <name>Name of Generators</name>
            <fields>
            </fields>
        </layer>
        <layer>
            <name>Name of Helipads</name>
            <fields all="true"/>
        </layer>
        <layer>
            <name>Name of Villages</name>
            <fields>
            </fields>
        </layer>
        <layer>
            <name>Name of Stations</name>
            <fields>
            </fields>
        </layer>
        <layer>
            <name>Name of Camps</name>
            <fields>
            </fields>
        </layer>
        <layer>
            <name>Name of Blocks</name>
            <titlefield>Block_name</titlefield>
            <fields>
                <field name="Block_name" alias="Block_name"/>
            </fields>
            <orderbyfields>Block_name ASC</orderbyfields>
        </layer>
        <layer>
            <name>Name of Communication Tower</name>
            <url>http://10.14.195.34:6080/arcgis/rest/services/Engineer/Engineer/MapServer/7</url>
            <fields>
            </fields>
        </layer>
        <layer>
            <name>Name of Seperator</name>
            <url>http://10.14.195.34:6080/arcgis/rest/services/Engineer/Engineer/MapServer/14</url>
            <fields>
            </fields>
        </layer>
        <layer>
            <name>Name of BVS</name>
            <url>http://10.14.195.34:6080/arcgis/rest/services/Engineer/Engineer/MapServer/13</url>
            <fields>
            </fields>
        </layer>
        <layer>
            <name>Name of Heater</name>
            <url>http://10.14.195.34:6080/arcgis/rest/services/Engineer/Engineer/MapServer/12</url>
            <fields>
            </fields>
        </layer>
        <layer>
            <name>Name of Tanks</name>
            <url>http://10.14.195.34:6080/arcgis/rest/services/Engineer/Engineer/MapServer/5</url>
            <fields>
            </fields>
        </layer>
        <layer>
            <name>Name of Manifold</name>
            <url>http://10.14.195.34:6080/arcgis/rest/services/Engineer/Engineer/MapServer/10</url>
            <fields>
            </fields>
        </layer>
    </layers>
</configuration>
RobertScheitlin__GISP
Mohammed,
   There Search widget does not have that capability. There is no other widget publicly available that have that ability already developed and ready to use. The one that comes closest is the eSearch that does not autocomplete but does provide a dropdown list for available data.
If you are a developer and want to add autocomplete yourself then see this thread AutoComplete for Text Input in VIEWER  for general details.
