AttributeInspector popup size-position
2503
10-03-2011 06:55 AM
NoloVegis
It seems alot of my attribute popups run off the bottom of my map/screen. Is there a way to control this? It happens on my Attributeinspectors and the popups. I have already limited the visible fields to what is required. I'm using the flex 2.4 viewer. Any help would be appreciated.
Nolo
philippschnetzer
I would like to accomplish something similar.  I would like to dock the attribute inspector on the screen and also be able to control the size of the text boxes that appear in the form.  I can't figure out where to change this stuff in the code...
philippschnetzer
I have searched through every mxml involved in the Edit widget (including skins from the api download) and have not been able to locate any piece of code which seems to figure out how large to make the input text boxes.  Is this some sort of built in flex feature or can this be controlled somehow?  I just want to make every input text box a single line only rather than have some as single lines and some as several lines with no means to control their size.
Can someone from the Esri Flex Team please comment on this?
Thank you!
ErwanCaradec
Up !
I've got exactly the same problem, is here a way to control the text boxes size ? It is very very very frustrating.
Erwan
