Attribute table widget - Column Widths & Horizontal scroll bar
2995
02-20-2013 02:22 PM
AnthonyGiles
Honored Contributor
All,
I think the new attribute table widget is excellent for quickly making edits to attribute tables without having to use the edit widget. One small problem which I think lets the widget down is when you have numerous attributes the column widths just get smaller and smaller to fit them all in to the width of the containing panel.
Has anyone modified the code so that all the column widths adjust to their content and the user can use a horizontal scroll bar to view the whole table.
Regards
Anthony
AnthonyGiles
Honored Contributor
Robert,
I see that the data grid you use for your esearch widget automatically changes the column widths to fit the data within them. How hard would it be to make the same changes to the out of the box attribute table widget so that you do not end up with tiny columns when you have a lot of attributes?
Regards
Anthony
RobertScheitlin__GISP
Anthony,
   Much of the actual AttributeTable component is not exposed (it is part of the API) so it will not be an easy task.
AnthonyGiles
Honored Contributor
Robert,
Thanks for the reply, I'll suggest in on GitHub as an enhancement,
Regards
Anthony
MichalKalafarski
I have the same problem. Have You found a solution?
regards
Michal
