Attachments include the search widget
957
07-02-2012 05:41 AM
AuraRamos_Lora
[ATTACH=CONFIG]15655[/ATTACH]Hello, I could tell if there are any search widget which also shows the attachments as I propose in the picture.
I'm not a good programmer and I'm using the excellent widgets programmed here, someone could help me, I need a widget that shows the attachment arising from any search of polygon or point
The image showed the two widgets SearchWidget.mxml and AttRelateInfoWinWidget.mxml
Greetings and thanks for your help
RobertScheitlin__GISP
Aura Ramos Lora,
  The new eSearch 3.0 (only) has a new attachment feature that you get access to from the popup following the search.
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
