Attachment Relate Info
1112
07-25-2012 02:18 PM
LeroyChristophersen
I have placed this application in my config file.  When it is runs, it displays an empty box as well as nothing in the title bar.  I have placed the Field names are what is listed in the ArcGIS Directory for the Service.  I am using the compiled version for 3 and modifying the IWT_311 xml file.  The attributes desired have been listed as "APN,Owner,S_Str" etc.  The zoom function works, so I know that the widget is operating.
Any assistance would be great.
RobertScheitlin__GISP
Leroy,
   Have you read the Attachment Relate Info Window Widget XML Configuration.pdf? Especially the part concerning the layer name? Also did you look at the "Example Main Configuration files" folder and the examples in there?
