. as thousand separators and , as decimal point  in Enhanced Draw Widget?
3572
5
01-15-2013 11:32 PM
Asta_KristinOladottir
Hi hi,
since i am located in Europe I would like to have points as thousand separators and comma as decimal points, is this possible using Enhanced Draw Widget??
here is my application:
http://atlas.lmi.is/is50v/
RobertScheitlin__GISP
Asta and Turid,
Version 3.5.1 of the eDraw Widget is now available.
TuridBrox
I agree: In Norway the comma is used as a decimal point, and a space is used as a thousand separator.
It would be great if we could choose which signs to use as a decimal point and thousand separator.
Asta and Turid,
  Sure I will add localization to the number formatting  based on the applications locale (nothing that you should have to do to  specify the decimal separator, etc). But you both will have to be using  the latest version 3.5 to get this enhancement. I do not add new  features to older versions.
Asta and Turid,
JuliaGalindo
Hi
I am facing a similar problem, I am located in Latin America and I need to use comma as thousand separator  but I get points. I have this problem in the attribute table and in the popups. How can I change it? Reading this post I thought maybe it is because I have the flex viewer 3.5 setting to Spanish (Locale) so change it to English, but nothing changed.
Thanks for the help!
Julia,
   The thousands seperator is set based on the Operating Systems locale in version 3.5.1. The locale for my live sample site is en_US and it displays a comma as the thousands separator.
