ArcMap Print/Export vs Flex Viewer Print/Export - Help!!
2191
10
03-17-2011 07:15 AM
grahamcooke
*i am using SFv 2.1 and ArcGIS 9.3.1*
I am writing a GIS web application in flex using the flexviewer which is designed to support users right across the country and negate the need for these users to have ArcMap on their desktops.  The application is designed to support the planning of military firing exercises and so printing and emailing maps around is a big part of the application. The idea of centralising the app and making it web-based is to force everyone to do things the same way and also to enable the planning to be taken out into the firing areas as necessary.
I have noticed a substantial difference in print quality when printing the same map from ArcMap versus printing it from Flex. i am using the out-of-the-box print widget and also the pdf export widget. Is there any way of making the image quality as good as that which you can achieve through ArcMap when using the flexviewer?
Anyone else encountered these issues at all? Any suggestions on anything I can do to improve things?
Hope someone can help!
TomSchuller
Hy,
just go to http://bitbucket.schuller.lu/pchprintwidget
or http://bitbucket.schuller.lu/pchprintwidget30
and click on "Source" -> build.
Could you make a printscreen of the problem?
Tom
