ArcGIS Viewer -  Logo Distorted?
2962
07-25-2013 08:13 AM
GavinMayeda
I have recently upgraded to version 3.4, and I have noticed that my County Seal is now distorted in to an oblong shape rather than round.
Is there a way to correct this without going in to the source code or creating a new County Seal with extended edges?
As always, all help and suggestions are sincerely appreciated.
AnthonyGiles
Honored Contributor
Gavin,
Unfortunately not, you can either resize your images to be as close to the original as you can or change a line of code in the headercontrollerwidget, see this post for more details on doing this:
http://forums.arcgis.com/threads/75025-Headercontroller-Logo-size?highlight=Logo
Regards
Anthony
GavinMayeda
Anthony,
Thank you for the response, but I don't see that code in the widget........
This is what I see in the HeaderControllerWidget.xml :
<configuration>
    <about>
        <width>300</width>
        <height>300</height>
        <content>
            <![CDATA[
                <p align='center' width='139' height='139'>
                    <img src='assets/images/globe.png'/>
                    <br/>
                    <br/>
                    <font size="+2"><b><a href="http://resourcesbeta.arcgis.com/en/communities/flex-viewer/" target='_blank'>ArcGIS Viewer for Flex</a></b></font>
                </p>
        </content>
    </about>
</configuration>
I have tried adjusting the width and height values, but the header itself is not adjusting.
AnthonyGiles
Honored Contributor
Gavin,
The code is in the mxml file not the xml, you will need flash builder to recompile the code,
Regards
Anthony
