Advanced print solution
153528
296
02-19-2011 10:52 AM
TomSchuller
Please find in the codegallery my first version of an advanced print solution:
http://www.arcgis.com/home/item.html?id=6809086326ea4c76bf026a32bb9dd698
The backend is developed in Java as a ServerObjectExtension: PChPrintSOE
The communication to the SOE is realized by the REST.
So, any client can be used Flex, Javascript, ...
I just created a simple FlexWidget.
Some features:
- full print over the rest api (usable by any client)
- export to pdf,jpeg,png,emf and mxd!
- view paper layout extent live on map
- make print on a "template" mapservice by keeping the predefined layout
- multi-mapservices/multi-server support
- add graphics on the map view positioned in map units
- add elements on the layout view positioned in paper units like scalebar, scaletext
The code is under full development:
- support for wms layer
- code clean up and reorganization
Any suggestions, remarques or help is welcome.
Live demo with public Esri mapservices (last print button):
http://gis.pch.etat.lu/flexViewerPrint/
   - use this print widget with your PChPrintSOE-enabled mapservices for high quality
   - draw first some graphics with the DrawWidget prior making your print (in mxd format)
TomSchuller
Burns86,
- to modify the scales, you have to edit the PChPrintWidget.xml file.
I didn't yet implemented an ImageService as I didn't worked yet with ImageServices.
Did you know a public ImageService on which I can make some tests?
Tom
RobertScheitlin__GISP
TomSchuller
Robert,
thanks.
Also using this Print?
Tom
Tom,
   No I am not using your print widget and SOE, I just try to monitor all post on the Flex forums.
TomSchuller
Robert,
did you already played with the PrintWidget in the Flex3/AGS10.1? Could you share any experience?
Tom
TomSchuller
Burns86,
I just added support for ArcGISImageServiceLayer in my latest commit:
http://bitbucket.schuller.lu/pchprintwidget/changesets
Let me know it it's ok or need to be improved.
Tom
Tom,
   Let me give you my opinion after 10.1 RC1 testing.
evanpicard
I'm pretty sure the firewall is turned off completely, but I'll give it a shot when I'm back in the office on Friday.  Thanks for the help.
Evan
The firewall is turned off.
I restarted IIS.
I can successfully ping both the IP address and the server name.
java -version works successfully.
administrator is a member of agsadmin
I am still stuck, it will not work.  same errors.
Where can I find information on the domain? I dont recall specifying one.  this is an internal server, I have an IP address (172.26.197.91), and a servername (mwellagsserver) , that point to the same thing.
please help!
C:\Program Files (x86)\ArcGIS\Server10.0\java\tools\soemanager>soemanager.bat -a 172.26.197.91 mwellagsserver administrator aVp105 PCHarcgisSOE.jar
C:\Program Files (x86)\ArcGIS\Server10.0\java\tools\soemanager>java -classpath "C:\Program Files (x86)\ArcGIS\Server10.0\java\lib\arcobjects.jar;C:\Pr
ogram Files (x86)\ArcGIS\Server10.0\java\tools\soemanager\SOEManager.jar" com.esri.arcgis.tools.SOEManager -a 172.26.197.91 17.26.197.91 administrator
Error: AutomationException occured while connecting to server 172.26.197.91.
Please check if username and pwd are correct or are members of agsadmin group.
AutomationException: Access is denied.
Disconnecting from ArcGIS Server "null"...Done.
C:\Program Files (x86)\ArcGIS\Server10.0\java\tools\soemanager>java -version
java version "1.6.0_16"
Java(TM) SE Runtime Environment (build 1.6.0_16-b01)
Java HotSpot(TM) Client VM (build 14.2-b01, mixed mode)
JustinConner
Could someone please explain the toRemoveLayoutElements tag? How does this need to be formatted and what exactly is it looking for. Could you share an example?
MattGiles
Hi Tom,
Just got around to testing the new widget with ImageServices and it seems to work flawlessly! Thanks for your help in adding scales as well!
One more thing - I assume i do not have to add the printSOE capability to each of my ArcGIS services since my ImageService does not have this capability and your print captured it anyways...?
Thanks again Tom!
