Advanced print solution
154287
296
02-19-2011 10:52 AM
TomSchuller
Please find in the codegallery my first version of an advanced print solution:
http://www.arcgis.com/home/item.html?id=6809086326ea4c76bf026a32bb9dd698
The backend is developed in Java as a ServerObjectExtension: PChPrintSOE
The communication to the SOE is realized by the REST.
So, any client can be used Flex, Javascript, ...
I just created a simple FlexWidget.
Some features:
- full print over the rest api (usable by any client)
- export to pdf,jpeg,png,emf and mxd!
- view paper layout extent live on map
- make print on a "template" mapservice by keeping the predefined layout
- multi-mapservices/multi-server support
- add graphics on the map view positioned in map units
- add elements on the layout view positioned in paper units like scalebar, scaletext
The code is under full development:
- support for wms layer
- code clean up and reorganization
Any suggestions, remarques or help is welcome.
Live demo with public Esri mapservices (last print button):
http://gis.pch.etat.lu/flexViewerPrint/
   - use this print widget with your PChPrintSOE-enabled mapservices for high quality
   - draw first some graphics with the DrawWidget prior making your print (in mxd format)
TomSchuller
mattias_j,
I'm currently in holidays.
So I'm having 'some time' to take a look at your problem. Is it still present?
Tom
SylvainKerdreux
sylvain.kerdreux.
does the generated mxd file contain invalid layers or are there no layers in it.
If there are no layers in it, that means that either the server couldn't access the lyr-files or the layer was invalid.
Could you post the server.log from ArcGIS Server in verbose log?. The reason should be written in it.
If ther are layers in it but they aren't displayed, please add the manually and check the difference between them in the properties.
Tom
here the log from ArcGIS Server :
ERROR unable to add mapservice layers for :http://vm-geotest/arcgis/rest/services/Fond_de_plan/MapServer 2011-09-07 11:04:04 layout.MapServer VM-GEOTEST
INFO3 addAGSMapServiceByLayerFile.agsMapServiceLayerUrl = http://vm-geotest/arcgis/rest/services/Fond_de_plan/MapServer?f=lyr&v=9.3 2011-09-07 11:04:04 layout.MapServer VM-GEOTEST ERROR AutomationException: One or more arguments are invalid 2011-09-07 11:04:04 layout.MapServer VM-GEOTEST
INFO3 mapService: http://vm-geotest/arcgis/rest/services/Fond_de_plan/MapServer 2011-09-07 11:04:04 layout.MapServer VM-GEOTEST
MattiasEkström
Tom
Yes, my problem is still present. I don't want you to spend all you holidays working on that, but I'm very thankful if you could find some time to look at it. 🙂
/Mattias
DavidCaussin
Hi Tom,
I have a question over the layout.
Is it possible to create our own layout...
For exemple, 2 parts on a A3 with the map above and the text,logo,.... in the other?
TomSchuller
mattias_j,
your log file "Now_when_annotations_works_but_msd_and_layout_doesnt" didn't contain any PrintSOE entries.
Could you please post a new log file the the opertation entries?
Mercator007,
did you think about a 2page layout? Is this possible in ArcMAP?
Tom
DavidCaussin
Hi Tom,
No on 1 page but with 2 section (1 for the map and 1 for the other elements(title,scale,....)
for exemple
MattiasEkström
Tom,
Here's some new log files.
/Mattias
JustinFail1
Hi Tom,
We're having issues accessing the resulting images from your SOE because the url that is returned does not match the virtual folder that we've specified for the output folder. This is because we are using our site under a different domain name via secure https access.
For example, under verbose logging the url is returned as follows:
handleRESTRequest.answer: {"outputFile":"http://<server name>/arcgisoutput/PrintTask_Printing_1316752688844_layout.jpg"}
Whereas, I was hoping that it would be:
handleRESTRequest.answer: {"outputFile":"<server output directory url>/PrintTask_Printing_1316752688844_layout.jpg"}
Is there a way that we can either configure your SOE, or ArcGIS Server, to ensure that our https output folder url is used instead?
Thanks in advance.
Justin
TomSchuller
UnkleJ,
you have to configure the virtual output directory on your "Printing" mapservice.
If you have configured it, could you please post the ArcGIS server log in verbose mode.
Tom
AshleyOwens
When I click "Print" I see "An error occurs during print". The tmpUrl displayed in the console is below. Notice the carriage return character at the beginning. What's the best way to remove that?
I can't test it in a browser - it doesn't copy the entire URL to the address bar and I can't type anything else - I think the limit is exceeded.
�?� http://servernm:8399/arcgis/rest/services/layout/MapServer/exts/PCHPrintSOE/printLayout?mapExtent={"xmin":-9365144.5,"ymin":3908651.5511669656,"xmax":-9305144.5,"ymax":3994751.5511669656,"spatialReference":{"wkid":102100}}&printOutput={"height":29.7,"resolution":100,"format":"pdf","toRemoveLayoutElements":["*"],"pageUnits":8,"borderWidth":[0.5,0.5,0.5,0.5],"mapRotation":0,"width":21}&mapElements=[]&layoutElements=[{"symbol":{"type":"pchNorthArrow","size":48},"visible":true,"xOffset":0,"geometry":{"x":0.5,"y":0.5},"yOffset":0,"anchor":"bottomleft"},{"symbol":{"type":"pchTextElement","textSymbol":{"type":"agsJsonSymbol","xoffset":0,"angle":0,"yoffset":0,"color":{"alpha":255,"red":0,"blue":0,"green":0}},"text":"Title"},"visible":true,"xOffset":0,"geometry":{"x":10.5,"y":29.2},"yOffset":0,"anchor":"topmid","name":"myTitle"},{"symbol":{"barHeight":5,"type":"pchScaleBar"},"visible":true,"xOffset":0,"geometry":{"x":0.5,"y":0.5},"yOffset":0,"anchor":"bottomleft","name":"myScaleBar"},{"symbol":{"type":"pchTextElement","textSymbol":{"type":"agsJsonSymbol","xoffset":0,"angle":0,"yoffset":0,"color":{"alpha":255,"red":255,"blue":255,"green":255}},"text":"© copyright pch"},"visible":true,"xOffset":0,"geometry":{"x":10.5,"y":0.5},"yOffset":0,"anchor":"bottommid","name":"myCopyRight"},{"symbol":{"mapUnits":8,"mapUnitLabel":"","backgroundColor":{"alpha":255,"red":255,"blue":255,"green":255},"separator":":","pageUnitLabel":"","type":"pchScaleText","style":0,"numberFormat":{"roundingOption":0,"roundingValue":3},"pageUnits":9},"visible":true,"xOffset":0,"geometry":{"x":0.5,"y":29.2},"yOffset":0,"anchor":"topleft"},{"symbol":{"includeAllLayers":true,"legendTitle":"Legend","exceptionLayerNames":["ortho2010_white","Orthophotos2007","Orthophotos2004","Orthophotos2001","topo_100k","topo_050k","topo_020k","topo_005k"],"exceptionLayerNamesStr":"ortho2010_white,Orthophotos2007,Orthophotos2004,Orthophotos2001,topo_100k,topo_050k,topo_020k,topo_005k","showLayerNames":true,"showLabels":true,"showHeadings":false,"type":"pchLegend","legendBackground":{"style":"esriSFSSolid","color":{"alpha":255,"red":255,"blue":255,"green":255},"type":"esriSFS"},"legendColumns":1},"visible":true,"xOffset":0,"geometry":{"x":20.5,"y":29.2},"yOffset":0,"anchor":"topright"},{"symbol":{"type":"pchPictureElement","pictureUrl":"http://intranet.pch.etat.lu/files/images/prix_carburants.jpg"},"visible":true,"xOffset":0,"geometry":{"x":20.5,"y":2.5},"yOffset":2,"anchor":"bottomright"}]&mapServices=[{"visibleIds":"2,4","url":"http://serverprd:8399/arcgis/rest/services/Facility/MapServer","alpha":0.796875,"type":"AGS","name":"ITS Facility"}]
