Advanced Java PrintSOE on ARCGIS Server .NET --Can't connect to server
6046
26
06-03-2011 06:24 PM
RuiboHan1
I was following Step 2 on http://gis.pch.etat.lu/flexViewerPrint/quickstart.html
At the setp of
soemanager.bat -a [server name] [domain name] [username] [password] PCHarcgisSOE.jar
I used the username and password to Arcgis server .net, which is ArcGISWebServices and mypassword, but got the error of
" AutomationException occured while connecting to server localhost.
Please check if username and pwd are correct or are members of agsadmin group.
AutomationException: null
Disconnecting from ArcGIS Server "null"....Done"
I am sure the username and pwd are correct and can also use them to log on the arcgis server manager, anyone has the same problem? Please help,  Tom?  Thanks in advance.
RuiboHan1
No, I gave up after many attempts. Let me know if anyone find a soluation.
TomSchuller
Hy,
I'm not sure but we can try an other logging:
Start the <ArcGIS-Home>\bin\javaconfigtool.exe and enable the "Java Interop Logging".
In your profile dir, you should see additional java logs, maybe they contain some informations:
  C:\Users\<username>\AppData\Local\ESRI\Server10.0\Java\Log
Tom
JimWard
Tom,
I don't seem to have the javaconfigtool.exe at the path you noted, or anywhere on my server for that matter. I have a .net install, not sure if that matters.
I will keep my eye out for any other suggestions anyone may have!
Thanks!
-Jim
JimWard
Could the version of java have anything to do with this error? I am showing 1.6.0_16
-Jim
JimWard
Just updated to Java last 6 build (1.6.0_27), as this was released in August, so should work. But no success. Same error.
TomSchuller
jimwardlewiston,
what's your ArcGIS server version and o  which ServicePack level are you?
Tom
JimWard
jimwardlewiston,
Tom
We are at server 10.0, .net, no service packs applied. Maybe that is my next course of action.
JimWard
Well, just installed arcgis service pack 3 for server, .net, and desktop, still get that same persistant
"Error: AutomationException occured while connecting to server [servername]   Please check if username and pwd are correct or are members of the agssmin group. AutomationException: Access is denied."
I am about to give up! Anybody got any suggestions?
Thanks!
Jim
JimWard
I have tried everything. I don't think there is anything wrong with Tom's code. I just think there may be something up with my install, my syntax (although I thought I followed everything to a 't'. Using this command line string to register the PCHarcgisSOE.jar or I would bet any jar file for that matter, just does not work.
So question, is there an alternate method to registering an SOE?
TomSchuller
jimwardlewiston,
did you have a possibility to give me remote access.
You can contact me by email.
Tom
