Add identify button to navigation widget
5865
6
01-17-2013 09:20 AM
AnthonyGiles
Honored Contributor
All,
I am trying to add an icon to the navigation widget that opens up the identify widget, i.e:
[ATTACH=CONFIG]20812[/ATTACH]
I have managed to do this by adding the following to the navigation.mxml:
in the array collection for the images added:
<s:ArrayCollection>
<fx:Object action="pan" imageIcon="assets/images/i_pan.png" label="{LocalizationUtil.getDefaultString('panLabel')}"/>
<fx:Object action="zoomin" imageIcon="assets/images/i_zoomin.png" label="{LocalizationUtil.getDefaultString('zoomInLabel')}" visible="false"/>
<fx:Object action="zoomout" imageIcon="assets/images/i_zoomout.png" label="{LocalizationUtil.getDefaultString('zoomOutLabel')}"/>
<fx:Object action="identify" imageIcon="assets/images/i_identify.png" label="Identify" />
</s:ArrayCollection>
and then changed the doNavAction function to the following:
private function doNavAction(action:String, label:String):void
   var data:Object =
       tool: action,
       status: label
   if(data.tool == "identify")
      AppEvent.dispatch(AppEvent.WIDGET_RUN, ViewerContainer.getInstance().widgetManager.getWidgetId("Identify"));
      AppEvent.dispatch(AppEvent.SET_MAP_NAVIGATION, {tool: "Pan",status: "Pan"});
   else
   AppEvent.dispatch(AppEvent.SET_MAP_NAVIGATION, data);
This opens up the identify widget as expected and sets the map navigation back to pan, but unfortunatly it does not change the selected icon to the pan icon, how can I represent a mouse click on the pan icon using code,
Regards
Anthony
RobertScheitlin__GISP
Anthony,
   Try this:
private function doNavAction(action:String, label:String):void {
    var data:Object ={
        tool: action,
        status: label
    if(data.tool == "identify"){
        AppEvent.dispatch(AppEvent.SET_MAP_NAVIGATION, {tool: "pan",status: "Pan"});
        var timeoutExample:uint = setTimeout(function():void{btnBar.selectedIndex = 0;},500);
   }else{
Anthony,
   Try this:
    var data:Object ={
        tool: action,
        status: label
   }else{
AnthonyGiles
Honored Contributor
Thanks Robert,
I'll give it a try when I'm in work tomorrow and yet you know how I get on
Regards
Anthony
AnthonyGiles
Honored Contributor
Robert,
Works perfectly thank you
Regards
Anthony
SaurabhGupta5
Hi Robert,
I am trying to use same code but timer clock is not going away even after adding timer. What shall i do now?
Thanks
Saurabh,
  Did you add the import for ViewerContainer?
import com.esri.viewer.ViewerContainer;
Also you need to add the following line to the  initButtonBar function
navAC.addItem({ label: "Identify", action: "identify", imageIcon: "assets/images/i_info.png" });
SaurabhGupta5
Hi robert, yes i made it working now. thanks but i want to do something different instead of opening existing widget from this location. i have started new thread for same.
Help on identify toolhel
Thanks for your help
