Accessing a Pdf File Stored in a Blob Field Using the Enhanced Search Widget
936
09-13-2012 07:47 AM
MichaelVolz
Esteemed Contributor
I have an Oracle based SDE feature class with a relate built from a query layer using SQL Server database tables.  I would like to be able to open up a pdf file stored in the Blob field of a related record that I can access from the related results tab of the Enhanced Search Widget, in similar fashion to a hyperlink or opening a file.  Is this functionality possible with the latest version of the Enhanced Search Widget?
RobertScheitlin__GISP
Michael,
   No that is not possible. I do not believe that the REST end point supports blob fields at all (ArcGIS Server limitation).
