How can we enable QuickEdit on custom vector tile services
1048
03-06-2019 09:39 AM
DominicStubbins
If I'm building a custom vector tile service, is there a way to structure the layers or tag it such that QuickEdit functionality becomes available?  The ability to just change a few colours or choose a theme is awesome and would be nice to make available on our own services
D
John-Foster
If you are starting in the ArcGIS Vector Tile Style Editor, you can only select from basemaps that use the Esri world basemap service or the OSM service in it. However, if you start with ArcGIS Pro, you may be able to start with other services. If you start with a tile service that is not based on Esri world basemap service or the OSM service, you will not be able to use the Quick Editor.
--jf
