Non-Metric-Related Data on Existing Conditions?
903
08-02-2023 03:52 PM
ScottEdmondson
Some of my planner colleagues are wondering if it's possible to have data on EXISTING buildings (name, address, GSF, height, etc.) and on FUTURE buildings (name, address, total GSF proposed, net growth increment of GSF proposed, by land use, etc.).
If we have that data, what are the options for making it accessible thru AGU?  in pop ups, or otherwise?  And HOW does one do it?
Any direction you can provide would be helpful.
Thank you,
ScottEdmondson
Hey Jason, Thanks. I'll see if that will work.  Cheers, Scott
JasonKarian2
Hey Scott,
What I would recommend for this is to use it in our "Indicators" Section!
This is where you'll have the premade webscene (make sure pop ups are enabled) with those buildings and data you mentioned, and you can add that to your new Indicator. From there when you select said Indicator, you should be able to select whatever feature you want and it'll have the data from the feature pop up!
ScottEdmondson
