Tracker settings in MDM (AirWatch)
941
03-06-2020 06:33 AM
by Anonymous User
Not applicable
We are trying to configure our MDM (AirWatch) in order to set the Portal url Parameter in Tracker but no luck so far.
https://doc.arcgis.com/en/tracker/help/deploy.htm
We are testing with iOS 13.3.1 on iPhone.
The same AirWatch config is working with Collector.
Are there additional settings to consider?
Thank you
CraigGillgrass
Hello Line, it's going to be a little tough to troubleshoot this without seeing the parameters.
A simpler way to handle this is to either take the conversation to our tracker feedback alias or work through Support.
Let me know which direction you choose.
Craig
by Anonymous User
Not applicable
Thanks Craig,
I am in Canada so I don't think we can go trough support? Not sure..
If I cannot open a case with Support, can you tell me what's the email of your tracker feedback alias?
Line
CraigGillgrass
Line,
You can go through Esri-Canada support, although it will take a longer to get to us.
The feedback alias for tracker is [email protected].  You can also access that email alias under Profile > About Tracker.
Craig
by Anonymous User
Not applicable
Can you confirm your configuration looks like?
What version of the app are you deploying?
