Can I add a layer to the Tracker Viewer?
1219
10-20-2020 03:50 PM
Natalie_Campos
I need to be able to add a polygon assignment layer to my Tracker Viewer.  If I cannot then I have to add the tracks to a web map and build a WAB app to view the tracks and the assignment boundaries. This makes using the WAB app very difficult as it is just to many points and the map viewer does not seem to have the smart rendering.
by Anonymous User
Not applicable
Hi Natalie,
Unfortunately, you cannot add other layers for viewing in Track Viewer. There are on-going efforts on multiple fronts to support these uses cases by adding new analytical tools to AGOL to process the track data and developing new renderering techniques that may eventually be supported by map viewer. Do you use AGOL or Enterprise?
Natalie_Campos
Currently, we only use Tracker in AGOL but have plans to use it in Enterprise as well.
