ArcGIS Pro 3.5.6 patch -- Now Available
603
03-03-2026 06:23 PM
jos20
by Esri Contributor
ArcGIS Pro 3.5.6 includes fixes for ArcGIS Topographic Mapping.
In the Thin Hydrology Lines tool, if a feature contains a value of 0 in the field specified for the Hierarchy Field parameter, the feature's visibility is locked by setting the value for the field specified in the Invisibility Field parameter to 0.
This was breaking hydrographic networks, especially where incorrect line direction was set in the source, or when centerlines were created in prior models that don't have a line direction set but have a hierarchy value set to zero.
Additional details:
  • ArcGIS Pro 3.5.6 is now available for download from my.esri.com.
  • You must have ArcGIS Pro 3.5 installed prior to installing this patch.
  • The Release notes and Issues Addressed List can be found here: Release Notes for ArcGIS Pro 3.5 (includes patch 6).
If you experience problems after installing this patch, please log a case with technical support.
We always welcome ideas, enhancements and suggestions on our ArcGIS Topographic Mapping Ideas page.
Contributors
