XLS form pulldata() not returning value
1734
09-19-2023 10:35 AM
AlannaHoffmann
Hello all, and thank you in advance for your help!
I am in the process of changing around a template for Survey123 to collect damage costs in the event of a disaster. I will eventually put this data into a dashboard to display the costs associated by county. There is a certain threshold that must be met by each county in order to qualify for assistance. The point of this dashboard is to track how close we are to meeting this threshold in each area (it is a different amount for each county).
I figured this could be a simple addition to the code in XLSform, keep it hidden on the survey, and then call to it in the feature layer and dashboard. I created the row for it, I added the column to the external_choices sheet, and tried to use a pulldata() formula to get the requested threshold amount so it would display once the county selector is activated in the dashboard. The problem is, although the new field is populating in the survey data, there is no value associated in the field. Below are photos of what I have input so far; the external_choices sheet, the code in the main sheet (2 photos), and the output in the feature layer in maps which is also blank in survey123 and when tried to input in the dashboard.
I have tried changing it from string to integer, deleting int, making the type hidden/text/note/calculate, changing the appearance, switching around the columns in the external_choices sheet, etc. I have saved the excel workbook, reloaded the survey, republished the survey with each change, resent the surveys in the app after changes are updated, and relinking the feature layer in the map. It still does not give the information I am trying to pull. I feel like this should be simple - what am I missing?
JamesTedrick
Esri Esteemed Contributor
Hi Alana,
Instead of using external_choices, you should have a dedicated CSV and retrieve teh value from that.  I'll note that the external_choices sheet is written into a CSV file called itemsets.csv, not external_choices.
AlannaHoffmann
Hi James,
Thank you for your reply!
I confirmed that the additional column was also uploaded into the itemsets.csv file in the media folder once I republished the survey, however I will try to create a separate csv. If I do this, will I need to create a separate "document" or can I just add a sheet at the bottom of this workbook? If I create a separate .csv, will I need to save it to the media folder and then make the calculation and republish the survey or can it just be saved to my local files on my computer?
Edited to add: I just tried changing the formula from 'external_choices' to 'itemsets' since the threshold column is included in that csv. It still did not show the value once I republished and resubmitted a couple of test surveys. I will try to save a separate csv for just the threshold amounts but I do not see how this would be different than including it in the sheet that is already a part of the survey?
Edited again to add: I added another sheet to the survey workbook named 'thresholds' and changed the formula to pull from there. I also saved it as a csv utf-8 file to the media folder in my survey designs, and updated/republished the survey. It is still not pulling the information.
