Workforce and Survey 123 integration
1241
12-05-2017 11:19 AM
JevitaWebster
i have created a project in Workforce and added Survey 123 integration. My problem is on on the ArcGis content page i cant seem to find the data that was created with the survey.
JamesTedrick
Esri Esteemed Contributor
Hi Jevita,
If you did not tie your survey to a pre-existing feature layer, Survey123 will create one and place it in a folder named Survey-<Title of Survey> .  You will also find the form item and, depending on how you have shared the survey 1-2 feature layer views (fieldworker for data add-only submission, stakeholder for read-only data viewing).
