Where can submitter delete their own records?
664
09-13-2019 06:49 AM
by Anonymous User
Not applicable
Under the collaborate, I enabled the "Add, update, and delete records" option for submitters.
With this, I thought the submitters can delete from the data tab, when they select their own records.  However, the delete icon only appears to me, the survey owner.  So from what interface within Survey123 can they delete their own records?
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Ahjung,
Currently, submitters are not able to delete their own records from the Survey123 website, but through other tools, such as a Web AppBuilder or other editing application.  The setting label is designed to describe the feature layer capabilities, not the operations available in the Survey123 website.
