Web browser: pull data function
506
02-11-2025 09:42 AM
chelseamg
I'd like to publish a survey using the web version and use the pull data function to populate answers if the user has previously filled out a survey. The user should be allowed to edit text, leave and return to the surevy to complete it on their own time. However, once a user leaves the page the pull data function re populates the previous answers. This is expected behaviour for the function, however I'm wondering if anyone has found a work around or has a solution.
This is not an issue on the field app version, however I'd like to avoid using the app.
The version of survey123 connect that we are using is 3.21.62.0
Thanks so much!
