Using the token parameter in survey123
13087
18
09-05-2020 01:54 PM
PaulSweeney3
Hi All Can someone explain how the token parameter can be used to access secure surveys . My understanding is you can generate the token and use it to bypass the login screen but it does nt seem to work for me
Integrate with other apps—ArcGIS Survey123 | Documentation
CarlosRuano1
I have a private survey only share with my organization and I tried to access with the following url.
https://survey123.arcgis.com/share/2af631ece9db4467825ba20913a8021e?token=tokencreated
The token is created each time the survey is loading, the token is working because I use the same token to access the feature layer and it works.
The survey app token stop working on friday and I have using it for a while with out any problem. The problem happens in Desktop Web browsers and mobile browsers.Error Survey
PaulSweeney3
Hi Carlos Ruano
Did you try to make the referer the actual form url as opposed to just survey123 website? You are experiencing the same issue as me only I am seeing this behavior on the desktop browser my form loads fine on the mobile device.
CarlosRuano1
Hi @PaulSweeney3
I add the survey url as you suggest and its works.
Regards,
Carlos
PatrickHassett
Hi @PaulSweeney3 , @JamesTedrick,
Adding the survey URL to http referrers did not change the behavior, I am still being redirected to the authorization page whenever I use a link with my oauth2 generated token. Any advice or insights? Thank you so much!
PaulSweeney3
Hi @PatrickHassett
How are you generating your token ? Can you elaborate on your process a bit more?
PatrickHassett
Hi @PaulSweeney3 , thanks for getting back to me. In the most simple application I would like to be able to use tokens generated from https://<host>:<port>/arcgis/sharing/rest/generateToken?, specifying  the survey URL as the client as shown in the picture below, and manually append them to survey links before sharing them with survey respondents. Thanks for your help!
PaulSweeney3
Hi @PatrickHassett
When you append it are you using the right parameter format (token=xxx)?
PatrickHassett
Hi @PaulSweeney3 , here is the URL format that I am using:
https://survey123.arcgis.com/share/xxxxxx<ItemID>xxxxxxxx?portalUrl= https://<host>:<port>/portal&token=xxxxxxxxxxxx<token>xxxxxxxxxxxxxxxx
PaulSweeney3
Hi @PatrickHassett
Sorry I cant definitively comment on launching surveys from a specific portal but the documentation does reference the following structure
@arcgis-survey123://?portalUrl=host.domain.com/webadaptor
@JamesTedrick  would probably have more helpful advice then me on this one I  would think.
