Using Barcode or QR code in Survey123 to update coordinates.
2091
09-29-2020 01:41 PM
DiegoLlamas
Hello,
I have a question. I want to use a Barcode or a QR code to scan some packages and collect coordinates where this package is. Because packages are moved and I would like that every time this is moved, i can scan the barcode and automatically update the coordinated so i can find it easier. is this possible?
DLL
James Tedrick
JamesTedrick
Esri Esteemed Contributor
Hi Diego,
It sounds like this could be implemented in Survey123.  It would be easiest to have a new form be collected for every movement of a box and then have a view that filters only the most recent record for each ID.
DiegoLlamas
Ok, so this action  that at this moment i cannot use barcode or qr code to update latitud and longitud fields. Thanks. James
