Use a hyperlink in Survey 123 field app to nagivate to a repeat record for editing
775
05-18-2025 08:33 PM
JessP_2711
I found this old post from 2021 regarding a link to navigate to records in a repeat in the Survey 123 Field app and wanted to check in there has been any updates since?
https://community.esri.com/t5/arcgis-survey123-questions/use-a-link-to-navigate-to-a-record-in-a-rep...
Our field team conduct flora surveys and can sometimes collect into the hundreds of records for one quadrat, and on occasion need to go back into a record to update values.  Pressing the next arrow many times is quite time-consuming and we would like to be able to make this process more efficient by adding a link to the record in the table to navigate to the record. Have any updates been made to make this function available?
GlenterpriseUK
Hi @JessP_2711
Looking at the documentation there hasn't been any update regarding this issue and as Ismael has mentioned in the previous post that you added, it is not possible.
Jumping between records in your repeats can be done only the right and left arrows.
If there is an update it will be featured on the What's New page What's new in Survey123—ArcGIS Survey123 | Documentation
Regards,
Glen
Neal_t_k
Maybe this should be thrown in the ideas, but in Connect and Field App, you get the TOC when you click on the pages at the bottom,  Could something like that be implemented for the repeats?
DougBrowning
MVP Esteemed Contributor
I posted that as an idea a few years back  https://community.esri.com/t5/arcgis-survey123-ideas/ui-to-move-to-any-repeat-for-survey123/idi-p/93...
The new 123 has an excel looking table in development.
JessP_2711
Thanks @DougBrowning I have voted on your idea, and actually found a few similar ones all dating back a few years, hopefully we see some development in this soon
DougBrowning
If you long press on the Next arrow it will go all the way to the end for you.  Best workaround I have seen for this.
