TypeError: i.getNodeFromItem(...) is null error in Survey123 web app when using select_one_from_file question type
1180
04-16-2021 06:53 AM
WhitneyWeber
In version 3.12, I'm using the new select_one_from_file option and receive the following error in the web form, but not in Connect or the field app:
I have stripped everything but the one field from the survey to verify that the select_one_from_file question is the problem. The csv file referenced has been added to the media folder, AGOL as a CSV file, shared, and linked within the survey.
JodyZhengLiu
Hi @WhitneyWeber ,
Could you try the survey on survey123beta.arcgis.com next week? We will update the beta website later this week and it should fix your issue.
Jody Zheng Liu
