Tricks to lining up fields in Reports?
770
08-09-2022 08:44 AM
DougBrowning
MVP Esteemed Contributor
I am trying to use Tab to line up fields in my report but it is not working.  I cannot find a pattern yet so wondering if anyone as a trick to fix this.  Thanks
Report template
Report
Katie_Clark
MVP Regular Contributor
I always format my report templates in tables, and you can hide the gridlines. That ensures that the data will appear where I expect it to 🙂
Example:
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
