Survey123 unique ID
11693
11-18-2016 10:09 AM
CraigClouet
Do people have any Survey123 examples of creating and the syntax for the UUID?
Tags (1)
IsmaelChivite
Esri Notable Contributor
typenamelabelcalculation
textuniqueIDUnique IDuuid()
IsmaelChivite
JamesTedrick
Esri Esteemed Contributor
The function is uuid() .  Note that if you want to create a GUID field (the default is text), you also need to set the bind::esri:fieldType column for it to esriFieldTypeGUID.  See the attached file.
