Survey123 Unable to Send Data - Continual Getting Service Information Message
873
09-09-2019 04:36 PM
SageTezak1
I conducted 2 surveys back to back, using 2 different forms. The first survey was completed in about an hour (form 1), and the data was stored in the Outbox (not uploaded). The second survey took about 6 hours, using form 2. Following the second survey the data was successfully sent. Can you recommend any actions to get the data from survey 1 off of the iPad? I've tried logging out of Survey123, turning off iPad, etc, and every time I try to send from the Survey123 Outbox, I get "Getting service information." Any suggestions are greatly appreciated.
Thank you,
Sage
JamesTedrick
Esri Esteemed Contributor
Hi Sage,
Does the survey in the Outbox have any errors from the submission attempt?
We have published a procedure for offloading data which is 'stuck' on a mobile device, see Troubleshoot—Survey123 for ArcGIS | ArcGIS  for more information.
