Survey123 Report Insert Text for Null Values
3455
6
07-25-2022 12:41 PM
RyanMcKenna
Hello,
Is there a way to have the feature report insert conditional text when no response was entered in Survey123?
I have a monthly inspection form with 15 numeric questions, but depending on conditions on site, some may be left blank intentionally. The project manager want to insert a text value like "N/A" or "Not Collected" in the report table rather then hiding these rows or leaving them blank.
I have tired ${decimal_1}${if decimal_1 == “”} N/A${/} based on another post, but this does not insert anything in the report, and ${select2}${if select2 != “”} N/A${/} which inserts "N/A" whether the question was answered or not.
I know I can add some calculations in the Survey123 form to flag if the question was answered as a work around but I would rather not as it changes the output table and adds to the development cost and I feel like there must be a way this can be accomplished in the feature reports.
Thanks
Ryan
ZenMasterZeke
Enter a default value.
RyanMcKenna
This is not always possible. If we are collecting something like pH or Temperature in the field, you cannot really add a default number to it if you did not measure it.
ZenMasterZeke
Could you default to something like -999 to indicate no measurement? Toxicologists here sometimes use the minimum detectable level in place of NA when having to use numeric values, since they can't actually say 0 when something could be present below detectable levels.
Another option, maybe: convert numeric values to text in another field in the survey and use that for your report.
MattEdrich
@RyanMcKenna did you ever happen to work out a solution for this? I, and many others on the forums, have tried exactly what you originally posted ( ${if ...==""}<TEXT>${/} ) to no avail. I read one forum post earlier with a response from an Esri Product Engineer that even signed off on that syntax, so it seems even Esri doesn't know how to do it if it is possible...
MichaelPellerin-Cavell
try this syntax it worked for me : ${if fieldname==null}...${/}
CaseyNowell
This corrected the issue for me. Thank you for your comment. This honestly should be pinned to the top and included in the conditional elements section of the survey123 report help page
