Survey123 pull data function returns only one intersecting polygon instead of all intersecting polygons
29
yesterday
ONeilkaBacchus
I am working with ArcGIS Survey123 and have encountered an issue with the pull data function when using a geopoint to query a polygon feature layer.
My survey contains a geopoint question that is used to identify intersecting polygon features from a single polygon layer. In many cases, the selected location falls within multiple overlapping polygon features. My goal is to populate a multitext field with the values of all of the intersecting polygons.
However, the pull data function only returns the value from a single intersecting feature, even when multiple polygon features intersect the selected location.
Is there a solution or workaround for this?
Thanks for the assistance.
