Survey123- Hosted CSV Linkedin content doesnt list as dropdown in ArcGIS Pro
729
08-07-2025 03:13 AM
AbdulabnanMohammed
Hi
I have published the CSV file to ArcGIS Online and I have created a Survey123 form and published the form and then updated the form with option - CSV Linkedin content and republished the form to show the list which was published in Online.
But when a surveyor chosena wrong value and want to correct it through ArcGIS Pro or ArcGIS Online because they are multiple records but i cannot see the dropdown .
I have just recorded a video of the issue any suggestion.
https://drive.google.com/file/d/1u-dkdcb1fUTa39uUNE0YhRqVd0G0oxAe/view?usp=sharing
The reason to use linkedin is periodically they will be updates to the list
Thank You
TylerGraham2
Yeah, when you use a CSV to create a list in Survey123 it doesn't create a corresponding domain in the feature layer. You have to manually create a domain and add values to it. I've had problems using the create domain tools in Pro in the past, so I usually use the AGOL web interface to do this.
In AGOL if you go to the feature service's Data tab, click "Fields," then click the field you want to create the domain for. You'll see a section called Domain and if there is no domain you'll see a button "Get Started" and you setup your domain through there.
It is annoying that you have to manage domains separately from the CSV files, but I think the reason it does this is because you can have duplicate names or values in the CSV list, but a domain has to have unique codes/values.
AbdulabnanMohammed
Thanks for the reply
@TylerGraham2 I just checked and added the csv list as per your guidelines but the pull function doesnt work any more .
Do i need to use service file in pull function
With linkedin content scenario, It use to download the csv in media and shows the list but now after adding the list ad guided doesnt work..
Any suggestion please
thanks
