Our organization is using Portal to host a feature service that contain all of our forms. Our issue at the moment is that survey123 doesn't support attachments on points and tables because when we activate the attachments on either one we get the following.."Supports ApplyEdits With Global Ids: False". It would be nice to allow our operators to use the image type in survey123 to draw sketches. Does anyone know a way around this? I don't understand why a feature would be added if it couldn't be accessed on an enterprise level using a feature layer.
Non-Versioned Feature Layers: Points & Tables cannot contain attachments or the GlobalID will be false when publishing.
Versioned Feature Layers: Automatically set to false.
hi. I have in our company working a feature on ms sql with attachments and repeats tables.
First the feature has to be not version. create the attachments for the feature from arccatalog. this table needs to be enable archiving and enable editor tracking.
Thank you!
