Survey123 Dates
664
11-19-2018 06:38 AM
ReneAubut
Hi, I can successfully perform a Date Query in ArcGIS Pro on a feature class but not on a Feature Layer created in Survey123Connect. My field team uses Android mobile devices, set on French Canadian meaning the dates are entered as YYYY-MM-DD. Any clue why i always get error msg "There was an error with the expression". Here is an example SQL syntax entered: Date_obs >= timestamp '2018-09-11 04:00:00'
RobertMEIER
