Survey123 Dashboard Print Current Response Customization?
6238
14
02-16-2017 06:33 PM
PeterTimmers
In the Survey123 dashboard you can print individual responses and it does a pretty good job of formatting, but is there any way we can customize that report?
Also, is the map supposed to zoom to the geolocation of the incident?  When I view the incident print preview it doesn't focus on the current point. You can manually zoom, but that's not ideal.  Nothing to do with being in the Southern Hemisphere is it?
Tags (1)
CarlHolt1
JamesTedrick
Esri Esteemed Contributor
Thanks, I've been able to reproduce it now.
ZhifangWang
cconnollyesriuk-esridistcqholttimmerspk
Thanks a lot for the detailed feedback, we're looking into this issue with JTedrick-esristaff and will let you know once it's fixed.
ZhifangWang
Hi all,
The following bugs have been addressed and fixed from your test results, all fixes will be released in the next 2.0 release (early April).
  • If I publish a new survey with no extent set, the map appears in the Individual Response section but the map shows the whole world
    • This is a behavior by design
  • If I republish the same survey with Preview Map and Detailed Map options configured, the map still appears in the Individual Response section but is centred over the west of the US
    • Bug: This will occur when setting a zoom level in Home Location of the map in a Survey123 Connect survey to a decimal value. Fixed: now both decimal and integer zoom level values will work.
  • If I publish a brand new survey, and configure Preview Map and Detailed Map options, no map appears in the Individual Response section
    • Bug: This will occur when setting the Default Map Type of the map in a Survey123 Connect survey to "World Topography". Fixed: now all map types in a Survey123 Connect survey will work.
Thanks again for your feedbacks!
erica_poisson
I realize that this post is from a long time ago, but I'm noticing some weird behavior that is related to this topic.
I published a new survey on top of an existing feature service today. Within Connect, I customized the map extent settings. I collected some test data, and the survey works perfectly and my collected geopoint shows up exactly where it should. When I go to the Survey123 website and view the Data page for my survey, the points appear in the proper location on the map showing in the top half of my screen:
When I click on a record and the record information opens up, the map shows this:
This survey also has a custom report template; the map within the report template also shows the Point of Interest as having no location (it's showing a piece of ocean off the coast of Africa, AKA the 0,0 coordinate).
I'm not sure what's happened here, or where I've gone wrong. Any suggestions would be appreciated.
Erica
Erica
