Survey123 Connect Upload File Question Support
1164
09-05-2018 07:56 AM
JAVIERVARA_SANZ
Good morning.
Could you provide an update whether or not Survey123 will support upload file questions?  I've noticed this has already been implemented for the web designer. If affirmative, is there a particular deadline in line? Unfortunately, my Survey is quite complex and requires Survey123 Connect to be deployed.
Thanks.
JamesTedrick
Esri Esteemed Contributor
Hi Javier,
As you note, file upload is available in the web designer and web form. It is technically possible to use a question of type file in Survey123; this will become a file upload question in the web form.  Note that file upload questions are not supported in the field app at this time.
JAVIERVARA_SANZ
Thanks James.
Sorry about the delay.
I’ve just tested it and it works great. Thanks for the tip.
Javier
