Survey123 Connect Pull location data for a geopoint from a hosted feature layer
2028
11-14-2024 10:10 PM
KeshavSingh
Hi there,
I was working on a project where I wanted to pull location data for a point from a hosted point layer. I was trying to use the pull data command, but it didn't return any value.
I tried to fix the UNITID, but still it doesn't return any value.
pulldata("@layer", "Latitude", "https://services8.arcgis.com/EnRf3TCZwFndmCJx/arcgis/rest/services/inspection/FeatureServer/0", "UNITID", "0737")
I may be using the wrong command here; can anyone please guide me?
2 Solutions
JillianStanford
If I'm understanding correctly, what works for me is to retrieve the location from a feature layer into a hidden field as JSON and then pull out the x and y from that.
Does that work for you?
JillianStanford
From your first post it looks like UNITID is a string?
Have you tried wrapping your where clause value in quotes?
concat("UNITID ='", ${UNIT},"'")
JillianStanford
KeshavSingh
Hi Jillian,
Thanks for the response. I created a new form to test this out.  But the pull function doesn't return any value.
I have attached the pull function syntax.
JillianStanford
KeshavSingh
Oh, shoot! Thanks for pointing out that mistake. It is working now. Thanks for the help!
