Survey123 beta
1516
02-25-2017 08:12 AM
MaikGrabow
Is it possible, to delete single surveys in Survey123 beta? I mean a filled form data, not the whole survey.
Thanks!
Tags (1)
DanPatterson_Retired
IsmaelChivite
Esri Notable Contributor
Hi.
We plan on adding a delete function in the Survey123 field app.
This option is planned  to be available in the Drafts, Sent, Inbox and Outbox folders.
  • If Delete is  triggered  in the Drafts and Outbox  folders, the survey data will be deleted from  your device.
  • If triggered in the Outbox or Inbox, then the survey data will be deleted from the local device AND your feature service.
We  are trying to keep  all discussions regarding the Beta builds of Survey123 in the User Forum within the Early Adopter Community web site.  This helps us avoid confusion between questions for Beta versus questions for released software.
Thanks  for your question!
