Survey 123 polygon feature , realted table
1216
09-10-2018 10:57 AM
NusratFatema1
Hi is three any way to us a polygon layer as a feature service , that will have a related table. If so please advice. I did read the following blog.
https://community.esri.com/thread/181809-survey123-feature-class-as-a-related-table
I was able to published the feature service as hosted. it only showed the top feature class field's (though I had domains assigned to it , it did not show. And when I try to add domains manually in the survey , some of them works some doesn't . please help/ I used the same  related table  with point features class and it worked fine but not with the polygon feature.
Thank You so much
Nusrat
JamesTedrick
Esri Esteemed Contributor
Hi Nusrat,
Can you share a schema sample of the feature class/table as a file geodatabase (fields & domains, no records necessary)?
JohnathanHasthorpe
Related information: Line and polygon support is now available in beta. Please go to the EAC site to start testing!: Welcome to our Feedback Community
