Survey 123 Feature Report Formatting
1021
04-18-2020 04:50 PM
EricStarn3
Hello All,
I have a feature report that I formatted but am having a problem with the formatting for a repeat (related table).
I get it to cycle through all the fields just fine but it mashes the last two fields together into one string.
Is there a good way to format that so it does not do that?
syntax
Key Leaders:
${#key_leaders}${position}
${pos_title} ${name}
${telephone}${/key_leaders}
Results
Position
Title
Name
PhonePosition
Title
Name
Phone
JamesTedrick
Esri Esteemed Contributor
Hi Eric,
Apologies for the delay.  Based on the layout you show, you should add a newline either at the top or at the bottom so that a line break either starts or finish the repeat; for example:
${telephone}
${/key_leaders}
EricStarn3
Thanks for the response.
I didn't realize you could add a carriage return after the last field and still have it work.
Thanks again,
Eric
