Survey 123 Data
1113
09-20-2018 09:38 AM
PattiSchmidthiesler
I created a survey and filled it out twice for testing, resulting in 2 records in the data. When I open the survey in 123 and go to the Data tab the fields appear but the data does not. The data appears in the analyze tab. I went into AGOL/My Content/{surveyname}/_fieldworker and there are only the 2 instances recorded. What is it directed to when saying there are 0/2000 records selected?  It states there are 0 of 2000 records selected.
JamesTedrick
Esri Esteemed Contributor
Hi Patti,
the "0 of 2000" is placeholder text that is filled with the real values once the data is loaded into the table.  It appears that something is going wrong with the loading of the data - can I ask that you open a support issue With Esri Support so that we can identify what is occurring?
