Sumar Valores en tabla repeat
913
01-17-2018 10:33 AM
PlaninforAdmin
al usar un repeat se crea una nueva tabla.... como puedo sumar los valores que se van ingresando a esa tabla en las diferentes posiciones?
JohnathanHasthorpe
when using a repeat a new table is created .... how can I add the values that are entered into that table in the different positions?
Survey123 supports the editing of repeats - so you can access the parent record in the inbox and either add or update the records in the related table. Please see: Prepare for editing existing survey data—Survey123 for ArcGIS | ArcGIS.
