Setting up a Inbox Query
4246
03-06-2018 08:16 AM
JoshHabel
Hello,
I would like to have an inbox query that looks at a field called "Quick_Pick" (this is a single select multiple choice question) and returns the survey to the inbox if the answer "Set_Return" is chosen.  Not knowing exactly how to go about this I have tried the following which has not worked.  Can anyone point me to how this should be written?
field name   =   choice name
${Quick_Pick} = 'Set_Return'.
Josh
by Anonymous User
Not applicable
Hi Josh,
You can find more information and examples regarding Inbox where clause queries in the Survey123 documentation: Prepare for editing existing survey data—Survey123 for ArcGIS | ArcGIS
Regards,
Phil.
JoshHabel
I was able to figure it out by going to the service feature Rest and trying out several queries.
Josh
