Setting a Temperature Range
7416
13
10-16-2019 10:02 AM
BRYANHERRON
I have a Survey question that is simply the temperature. Our field guys won't be working on days that are -200 degrees or 200 degrees, but I can't figure out how to force there answers to the question between a certain range. How do you do this?
JeremyJohnson5
In the constraints field try the following: .>-20 and .<120
RobertBorchert
Honored Contributor
Set up a domain for the question that has a ranged value.  You can set the minimum and the maximum.
BRYANHERRON
Easy for you to say. hehe
I am not familiar with setting up a domain.
JeremyJohnson5
If you are using Survey123 Connect you could set up a Constraint that would limit the values to be entered.
BRYANHERRON
I can't get the constraint's syntax correct for a range of -20 to 120.
RobertBorchert
Honored Contributor
-20 to 120 goodness I wish.  We have a range of -40 to 110.   But for safety concerns we don't send out crews when it is that cold.
BRYANHERRON
The work our guys do usually can't be done when the ground is frozen, so -20 may be giving them a lot of leeway.
RobertBorchert
Honored Contributor
Well at least Gators are not a concern.
JeremyJohnson5
BRYANHERRON
Yep, I thought I had tried that as well.
I have Gremlins...
