Round calculator output
1280
01-28-2019 12:36 AM
Nicole_Ueberschär
Hello folks,
I have an integer question field with the calculator appearance setting. The output of the calculator gives two digits which makes the answer to my integer question invalid. Is there a way to round the output of the calculator output? (That would be my prefered way...)
I guess the alternative way would be to use decimal answer and bind::esriFieldTypeInteger? Does that work?
Tags (1)
Jim-Moore
Hi Nicole
Just to clarify, you would like the user to be able to submit a decimal for a question, but only store a rounded integer for that question?
I'm fairly sure setting esriFieldTypeInteger on a decimal question would truncate the input instead of rounding it (e.g. input of 546.82 would result in 546).
One option could be to make the input a decimal question with calculator appearance (and optionally use bind::esri:fieldType = null so that it's not stored in the feature service), then have a hidden question (with esriFieldTypeInteger) using the round formula in the calculation column, e.g. round(${decimal},0).
Hope this helps,
Jim
Nicole_Ueberschär
Thank you for your input Jim! That could be a workaround. I will see how the enumerators feel annoyed by the current functionality. I have like 30 fields where I would have to do it the way you described it but I don't know yet how handy the calculator comes or how much it will be really used.
