Reverse Geocode from geoshape
2964
07-09-2020 06:43 PM
ChrisRoberts2
I am hoping that someone has a bright idea here, because I am out of them.
I have a Collector/Explorer app with a link on the pop up for the Parcel Layer, that parses the boundary coordinates to a geoshape question in Survey123 .. that bit works great.
What I want to do is in Survey123 is perform a reverse geocode on the Geoshape to get the street address.  It would appear, obviously, that the pulldata("@geoshape",${location},"reverseGeocode.address.Street","https://xxxxxxxx/server/rest/services/Locators/xxxxxxx/GeocodeServer") calculation doesn't work for a geoshape question.
So I came up with a solution to add a geopoint question inside a repeat (because you cant have a geoshape and geopoint in the same form unless one is in a repeat) and use that to reverse geocode on. Now that works in the form itself, so tick!.
Then I thought I could calculate XY centroid of the poly in Collector using Arcade, tick, then parse that to the geopoint question.  HOWEVER, I have since found out that parsing information from Collector to Survey123 to questions inside a repeat isn't supported.
Anyone have any solutions?  Any help would be greatly appreciated!
ChrisRoberts2
I think I cracked it!
For those that are interested:
I added two lat and long  hidden null fields outside the Repeat in the survey.
Then in the geopoint question added a concat calculation 'concat(${latitude}," ", ${longitude})' using  those two fields.
I then just use
pulldata("@geopoint",${location},"reverseGeocode.address.Street","https://xxxxxxxx/server/rest/services/Locators/xxxxxxx/GeocodeServer to grab the street address
In the launch url I parse the poly centroid xy to the hidden lat and long fields in the Survey form and a geopoint is created at the centre of the polygon and the address is populated.
Happy Days!
ChrisRoberts2
I then just use
Happy Days!
CherylWheeler11
Hi Chris, I wonder if you could elaborate on "In the launch url I parse the poly centroid xy to the hidden lat and long fields". I am attempting to extract the geoshape centroid and not sure how to do this.
Thanks very much for your help
ChrisRoberts2
Hi Cheryl
I extract the lats and longs for the centroid of the Parcel Polygon in Field Maps/Explorer using Arcade (I found on the forums and slightly tweaked):
function MetersToLatLon(mx, my) {
// Converts XY point from Spherical Mercator EPSG:900913 to lat/lon in WGS84 Datum
// Fuente: http://www.maptiler.org/google-maps-coordinates-tile-bounds-projection/
var originShift = 2.0 * PI * 6378137.0 / 2.0;
var lon = (mx / originShift) * 180.0;
var lat = (my / originShift) * 180.0;
lat = 180.0 / PI * (2.0 * Atan( Exp( lat * PI / 180.0)) - PI / 2.0);
return [lat, lon];
var poly = Geometry($feature);
var result = "";
if (!IsEmpty(poly)) {
var pnt_centr = Centroid(poly);
var latlon = MetersToLatLon(pnt_centr.x, pnt_centr.y);
result = latlon[0] ; //returns latitude replace with [1] to get longitude
} else {
result = "";
return result;
and in the launch url I parse those expressions to the lats and long fields in the Survey123 form.
eg
https://survey123.arcgis.com/share/xxxxx?portalUrl=https://xxxxx/portal&open=menu&field:longitud...
hope that helps
