Required Signature Image
3604
09-04-2015 11:45 AM
RonKnepper
Ok so I am guessing this is just a restriction of the use but if you set up a signature image and make it required Survey123 does not recognize if a signature is done so you cant send your survey.  Is this just a limitation or am I doing something wrong?
IsmaelChivite
Esri Notable Contributor
Not your mistake: This is just our oversight.  Please add an enhancement request in the repo. If a signature question is flagged as 'required' we should not let you submit when the signature is completely clear.
Thanks a lot. Good catch.
IsmaelChivite
RonKnepper
Its a holiday weekend!  No working.  Will do, actually your point is correct too but I mean even if you have a signature in the box and its required then it will not allow you to submit.
RonKnepper
Posted in github as I dont seem to have access to the link you gave.
IsmaelChivite
Thanks! Sorry, I provided wrong link.
