Repeat with 1:1 Relationship?
1148
06-04-2019 05:31 AM
TL2
Is it possible so have a repeat with a 1:1 relationship.  I keep getting an error and want to verify this is not possible.
Tags (3)
DeonLengton
You can limit the number of related records by limiting the repeat_count of the repeat section in your survey to 1.
TL2
Thanks Deon,
The goal is to be able to utilize the 1:1 pop-up configuration where you can add the actual values instead of the related field count.
JamesTedrick
Esri Esteemed Contributor
Hi T L,
Currently the 1:1 relationship type for existing feature services is not supported.  I've created an issue to consider supporting this relationship type in the future.
