Repeat feed a choice
1105
03-12-2018 04:15 AM
StuartMoore
in Survey123 is it possible to dynamically create a choice based on the answer of a question within a Repeat:
example:
if i have a question in a repeat called 'Name'
and it has been populated as follows
Record 1 - John
Record 2 - Bob
Record 3 - Anna
and then if i have a question outside of the repeat which is a choice driven off the Name question it would show the options: John, Bob, Anna
thanks
Stu
Tags (3)
BrandonArmstrong
Hi Stu,
What 'type' of question (text, select_one...) would you be using within the repeat?
We do not currently support the ability to dynamically create a choice list for a question based on the answer(s) of a previous question.  As I could see this being a useful feature, I will add it to our internal repository for consideration.
Regards,
Brandon
StuartMoore
Hi Brandon,
for what I had in mind a text type would be good but also a numerical type would be useful too
I'll keep an eye out for future releases
many thanks
Stu
